accent light switch on all the time
Lhandley00
Member Posts: 10
the switch is lit all the time on or off assuming a ground or wiring issue
Switch is probably defective. Those switches snap into the panel (tabs on the edges) and this can be easily changed out by removing the 6 screws and bringing the assembly out. Maybe you could flip the switch back and forth rapidly, see if it goes off? Nonetheless it’s an easy repair if you can get a replacement from nuCamp or a local RV parts distributor.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1
I think this is a wiring issue. The switches have separate terminals for the switched load and the LED. Looks like the LED was wired to the wrong side of the load switch. When you pull the panel, look at how other switches are wired and copy those.
Roger and Sue Hill | 2020 T@B400 Boondock (Cryst@bel) | 2022 Land Rover Defender 110 - P400 | San Juan Island, WA1
- 922 Introductions
- 411 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
