Dimmer switch replacement for the TAB400 rocker switches?
madtrout
Member Posts: 63
Has anyone found a dimmer switch that would swap out with the existing rocker switches for the lighting in the TAB400? The leds are nice, but just a bit too bright at times. Thanks, Mark
2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland
2008 Toyota Tacoma
I haven’t seen one but you should be able to retrofit one easy enough. Amazon has many and here is one for openers.https://www.recpro.com/rv-12v-dc-toggle-style-light-switch-with-high-side-dimmer/
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ -
In one of the many T@B / T@G modifications YouTube videos, someone installed colored cellophane sheets inside the light fixtures to provide a warm glow as they didn't like the bright light either.
Thanks for the tips.2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland -
Good chance they aren't dimmable. You have to have leds that are designed to be dimmed and then a compatible dimmer switch.
I would find out if they can be dimmed before retrofitting a dimmer switch.2019 T@B 400 Boondock Lite -
@N7SHG_Ham, I agree. It seems there was a post 3 or so years ago and it was determined that most of the LED’s used then in the T@B’s were not dimmable.Verna, Columbus, IN
I'll contact NuCamp on Monday and find out if they are dimmable.2021 T@B400 Boondock
2008 Toyota Tacoma
I chose this route, purchasing color gels (Rosco #204 CT Orange) from a professional photography site. I then used a paper cutter to cut long strips of the gels to fit into the tracks that hold the LED strips. The gels provided a much more pleasing color temperature and softened the recessed lighting in the cabin. The sheet of gel material was less than $6 dollars.MelanieAllred said:In one of the many T@B / T@G modifications YouTube videos, someone installed colored cellophane sheets inside the light fixtures to provide a warm glow as they didn't like the bright light either. -
Excellent idea, thanks!2021 T@B400 Boondock
2008 Toyota Tacoma
- 919 Introductions
- 406 Service/Maintenance & Recall Notices
