Costco GC2 6 Volt Batteries (Interstate) @ $79 each
Camco Heavy Duty Double Battery Box with Straps and Hardware - Group GC2
Stromberg Carlson 2020-Jr Bottle Rack for 20 Lp Tank
Cable for 6 volt to 6 volt connection
SNUG Fasteners for connections
Here are the steps I went through to make the change:
The process was to first remove the existing box and cut the LP Bottle Rack out of the storage area
Because the fit is so tight with not much more than 1/2 of extra space you will need to trim down the battery box including the plastic handles on the ends and cutting down the lid. I used a cut off wheel which made the cutting fast and easy.
Route the straps and attach the battery box. I used the original self tapping screws from the group 27 box.
Next I attached the new LP hold down which is far more compact than the original one and sadly they welded the original one so I had to cut it out anyway.
And the finished product all strapped in! I hope you all find this useful and please share other ideas you might have as I am always looking for a new project LOL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
2018 320S Outback
