Adapter for campground with 50 amp outlet
sbhtennis
Member Posts: 69
I will be traveling to Utah this spring. One of the campgrounds said I will need a 50 Amp adapter. I have a 2016 Tab 320 max S. My cord is a nice heavy duty one that I usually plug into the 30 Amp circuit at a campground .
Does this look like what I want to order to hook up at a site with a 50 amp socket ?
RVGUARD 30 Amp to 50 Amp RV Adapter 12 Inch, TT-30P Male to 14-50R Female Dogbone Electrical Converter with LED Power Indicator and Grip Handle, Green
This is the dogbone you need:RVGUARD 50 Amp to 30 Amp RV Adapter 12 Inch, 14-50P Male to TT-30R Female Dogbone Electrical Converter with LED Power Indicator, GreenThe description you provided would do the wrong conversion 30A to 50A, not 50A to 30A.Roger and Sue Hill | 2020 T@B400 Boondock (Cryst@bel) | 2022 Land Rover Defender 110 - P400 | San Juan Island, WA
ok thanks a lot.
So just to confirm - The male end of my current cord would go into the female end of the new Green 'dogbone' cord and the Male end of the green 'dogbone ' cord goes into the 50 Amp receptacle at the campground?
@sbhtennis, yes.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
- 915 Tips & Tricks
