Towing with a Honda Ridgeline?
trimtab
Member Posts: 237
Wondering what you may be pulling and how happy are you with the Ridgeline? ( looking at a 2020 )
2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E
Towed by 2014 Touareg TDi1 -
Hi, trimtab I have a 2020 ridgeline RTL-E it tows great, back in late august went from Ohio to Seattle and back avg. mpg 14-16. I have a 2017 320 CS-S I hope this helps ..2017 T@B CS-S Max ... 2020 Honda Ridgeline RTL-E0
2019 Ridgeline. Back and forth across the country this year, about 7500 miles plus local trips. Through Yellowstone and the Bighorn National Monument, so lots of climbing and descending. No problems, comfortable, quiet. Downshifts quite a bit on climbs but no overheating. Towing the 400 basically halves the mpg, averages about 12.5. Wind does really knock it down further. Wish it had a bigger tank.We use an e2 WDH, it tows fine with a regular hitch but the WDH does help control bump bounce.2019 Honda Ridgeline RTL TV
Poughquag, NY0 -
2017 RTL-E towing 2018 320S. Tows great and averaging almost 18 mpg at normal highway speeds.‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI0 -
We tow our 2014 Tab 320 with a 2019 RTL. The Ridgeline pulls the camper just fine. I feel that it's a good combination.2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota0 -
THANKS ALL!2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E1
