Aims Yellow Light
Kamate
Member Posts: 26
Finally took ‘21 Tab 400 BD out for our shakedown. Hooked up to camp 30a, no water or sewage since temps in low 20s. Keeping warm with Alde.
Noticed that the Aims Inverter light that is usually green when turned on, now goes from green to yellow after a few seconds of turning inverter on. Trying to figure it out but forgot manuals at home (along with my jacket). Getting jacket first thing once things open up around here. Thought I’d search the knowledge-fountain-of-all-NüCamp-wisdom but couldn’t find an answer...yet.
Hope someone can put my mind at rest as I’m concerned I messed something up.
TIA.
AJ & K
Virginia
2021 T@b 400 BD (N@lu 'Ima Ola)
2013 Toyota Tundra Ext. Cab V8 5.67L 4x4
Virginia
http://www.aimscorp.net/documents/PWRIX200012SUL%20May%205%202018.pdfOn diagram, page 4 it says yellow means you are in AC mode, green is inverter mode.
Hope that helps.2021 T@B400BD / Lewes, DE -
Th@nk you very much for the assistance and link!!!AJ & K
Virginia
- 915 Tips & Tricks
