Beeping
I'm not sure what is beeping inside my camper. It was put away in October. Battery is out and propane is shut off. It beep every once in a while. It just started today. I guess it the LP detector?
    pthomas745pthomas745 Moderator Posts: 3,701
    With no battery, the LP detector won't work.  The gas detector also has a series of flashing lights that you cannot miss when they go off.
    What does alarm, just like your home, is your smoke detector, which has a simple 9v battery.  Don't know what year you have...but look for it in an elevated location.
    banjer54banjer54 Member Posts: 21
    Thanks it a 2019 and it was the smoke detector. it took a while to find it, I have a lot of things stored inside for the winter. It will get a fresh battery come spring
