Upholstered panel button removal
2022 Tab 400. Does anyone know how to remove a button? Panel is loose at one ceiling edge spot at the front of the bed. It seems a fastener underneath has come loose from its mounting to the trailer frame. I assume the first step in fixing this is to remove the nearby buttons. Thanks
  • bergger
    Just pop it off with a flat head screw driver. That will reveal the screw head underneath it.
    2021 T@b 400 BD  "Vixen Gail"
    Leadville Colorado
  • ColMag
    ColMag Member Posts: 27
    What are these screws screwed into? I would have thought an aluminum frame crosspiece??
  • vhollow
    vhollow Member Posts: 97
    No, most of them are just screwed into the thin inner lining of the trailer.
  • XenanMe
    XenanMe Member Posts: 85
    Best way to fix the issue is to apply a small dab of adhesive silicone around the screw area and push the panel back up.
  • manyman297
    manyman297 Member Posts: 1,434
    A couple of mine pulled loose so I had to superglue some toothpicks into the holes, let it dry and then screw back into them. It’s been fine for over a year.
    2021 400 BD
    2020 Tacoma TRD Off-Road
