Miscellaneous annoyances
KathrynDyer
Member Posts: 5
Is it possible to get new wire shelves for the Norgold refrigerator in my 2018 T@B 320? The original shelves are rusting through.
Also, I had problems with unlocking, and then opening the trailer door. How difficult is it to replace the door handle?
We just replaced or refrigerator shelves for similar reasons. We got two shelves from Norcold directly. We found two shelves on the door and tall things in the body of the refrigerator allows it to hold more and have better access in use. I put some weather stripping on the back of the shelf to keep it from bouncing off while towing.
I haven't had issues with my '18 door handle yet. There are number of handles available. You may consider a combination lock handle replacement. If you are going to replace it anyway, you may as well make it better.2018 320CS-S
"Just Enough"0 -
You might just need to adjust the striker plate to help the door opening/locking.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S1 -
Try some dry lube on, and in, the door latch mechanism.
We've had trouble once or twice when the Tab wasn't well leveled, but a change in the levelers seemed to correct it.
If you want to change the lock to a combination-lock the RV-Lock is excellent.
Look here for a discussion: https://tab-rv.vanillacommunity.com/discussion/5690/rv-lock-keyless-for-rvs-is-great-currently-for-t-b-s-max-and-t-b-320-pre-2020-only
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1
