Using Jensen DVD player
Linfran
Member Posts: 2
Having a problem with dvds that just continue loading and never start. Any help would be appreciated!
That's not sounding positive.
Assume you have tried different CD Disks . . . .
My Jensen {DVD Reader Style} unit has only had "loading issues" when I inserted Blu-Ray disks instead of the slightly older format DVD disk.
And I felt soooo dumb for having brought the Blu-Ray movies - - - -
Adventures: 59 Nights: 411 Towing Miles 50,3501 -
We have a 2019 T@B 400 that had a loading issue that some first aid was in this thread if you have that model
https://tab-rv.vanillacommunity.com/discussion/9927/2019-jensen-jwm70a-dvd-cd-radio-loading-loading-loading#latest
ASA replaced ours even though out of warranty2019 T@B 400 Boondock Lite towed by 2016 5.7L Toyota Tundra
Assuming you have a DVD disk, try a music CD. If it loads correctly, your movie disk is bad. If the music CD doesn't load either, the lens on the laser is dirty. I cleaned mine; however, it took a lot of disassembly. I wouldn't recommend it without serious consideration.2018 320CS-S
"Just Enough"1 -
thank thank you - will try that0
In addition to other suggestions, I'm just going to mention that it will not play BluRay disks.
