Our 2018 320-CS has the Alde 3010 which is heating the cabin and water very well, but on our last two trips it began making an odd sound while in use. I'm not sure how to describe it but I'd say it's a mechanical 'clunk' that lasts about one second, and occurs I belive during the circulation process. The only thing I can come up with is that perhaps there is some sort of old style thermostat that expands or contracts due to the temperature of the transfer fluid? This past weekend we had it using both propane and electricity - perhaps it is related to only one source, but I guess the only way to test it would be to run it on propane and see if I can recreate the noise, and then repeat the process using electric only. Anyone have any ideas about what may be going on here?
Thanks, Jerry
0 ·
Thanks, Jerry
B] Are you using Propane or 120VAC as the heat source.
C] What elevation (altitude) are you camping
My experience with the 3020 at elevation on propane is that the 'Freight Train' noises come and go, do not always sound the same, and do not happen at every camp site; but with a 3020 always go away if the 3020 is placed in Mountain or High(er) Altitude Mode.
Adventures: 53 Nights: 334 Towing Miles 42,600+
Thanks, Jerry
