5 weeks later...I purchased the variable motor that was recommended by MuttonChops and others on Amazon. I have a question: It looks like the variable motor has a small fuse attached. If so, can I eliminate the stock fuse that is taking up space and a needed hole? Getting there...slowly. With appreciation, Michael
2015 Boondock
0 ·
Adventures: 56 Nights: 379 Towing Miles 47,220
Keep the standard fan fuse [SFF] and PCB fuse.
Check PCB fuse value and consider using a smaller value in the SFF.
The PCB used in my installation also has the PCB fuse; I kept the SFF.
Why:
If the PCB fuse blows, it will be difficult to verify and/or replace.
