Allpro awning mod
tinknocker
Member Posts: 22
Often find the Allpro awning support legs are too short due too ground being lower then the parking pad and sometimes the pad runs uphill alittle which requires the raising the trailer front to level. Seems maybe the awning was designed for the standard model and not the taller Boondock version.
The awning has an
adjustable leg on the tail end only so I decided to fab 2 foot long leg extensions for both ends using 1 inch OD aluminum tubing, tent pole clips and plastic push plugs. Tubing and push plugs bought at local hardware store and tent pole clips at Amazon.
The awning has an
adjustable leg on the tail end only so I decided to fab 2 foot long leg extensions for both ends using 1 inch OD aluminum tubing, tent pole clips and plastic push plugs. Tubing and push plugs bought at local hardware store and tent pole clips at Amazon. 1
@Tinknocker excellent!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
