Dewinterizing a 2021 T@B 320CSS
Canyoneer
Member Posts: 13
Any tips on de-winterizing a 2021 T@B 320CSS (Nautilus water system) would be appreciated, I don't want to haul it to the dealer and spend the $$, when I think it can be a DIY projects. Thanks.
Hi,
Have you seen this? There is one for the Nautilus system,
Dewinterizing and Sanitizing (vanillacommunity.com)
2025 360 CS
Southern Maryland -
You also could use the Nautilus Winterize settings to siphon in clean potable water and clear the antifreeze out of the water lines and the water pump.2021 400 BD / 2016 VW Touareg / Austin, TX
Thank you, for the easy to use methods. Happy trails.
- 919 Introductions
