Microwave replacement with convection.
zappa
Member Posts: 3
Does anyone know if the REcPro 1.1 cubic foot convection replacement for rv microwave will fit in a 2020 tab 400? Has anyone used this or any other convection replacement for the microwave (installed in place of). Is the additional heat generated by a microwave a liability for the camper? thanks
Did you ever end up installing the convection/microwave replacement in your Tab 400? I'm interested in doing the same thing.0
I’m looking into the same thing to replace the microwave with a broiler unit for toasting and baking. Toasting in the pan is getting old and would like a better baking option than the Coleman portable stove (which is used outside).2021 Tab400 boondock, 2019 Jeep Grand Cherokee Trailhawk0
The problem is the cutout is an odd size than a typical RV convection oven. You need one made for and RV because they blow the hot air out the front. A typical one from the big box stores do not do this and you will have problems with the heat build up.0
After research, I’ve opted to simply get a Cuisinart TOB 1010 oven toaster. Should store away easily in lower cabinet. I had to rethink about storage room and come up with a better idea for cookware.2021 Tab400 boondock, 2019 Jeep Grand Cherokee Trailhawk0
