how to install LEDs
Chiprchuk
Member Posts: 23
Hi Folks,
I am looking to install a strip of RGB LEDs in our 2019 Tab 320. We bought our Tab used and it contains Solar panels, 4 100AMP LIon batteries an Ampinvt 3000W inverter.
I am thinking about this set https://www.ledwholesalers.com/v2/index.php?route=product/product&product_id=780&search=20108 & this controller https://www.ledwholesalers.com/v2/index.php?route=product/product&product_id=857&search=3370.
So - being that electrical is not my strong-suit - I thought I'd ask you folks. How do you think I should install it? Connect direct to the Battery bank w/ fuse? Get a transformer and plug it in to a 110 socket? try and add it to an existing circuit? or?
TIA,
Chuck
TIA,
Chuck
Tab 320-S Boondock Edge 2019
T/V Ford Ranger 2023 4x4
I'd tap an existing 12v circuit somewhere, with an in-line mini ATM fuse between the tap and the controller.
You could also wire it into the stock 12v bus bars. Again, make sure to put an inline fuse on it.Northern VA
2022 T@b 320 S / 2021 Subaru Outback
- 915 Tips & Tricks
