2019 400 Black Tank Sensor Locations?
Does any body happen to know on which side of the black tank the level sensors are located in a 2019 400?
Rich
2019 T@b 400
Bellingham WA
    MuttonChops Member Posts: 2,085
    I have no direct knowledge . . . based on Factory Tour pictures and how the 320S (black tank models) were done . . .
    First place to look is the CoolCat Cabinet.
  • Horigan
    Horigan Member Posts: 924
    edited May 2023
    Thanks @MuttonChops.
    FYI.  I found the sensors using a mirror.  They are on the forward right corner of the tank.  The sensors (screw heads) looked pretty clean, even though I get erroneous full readings.  Hopefully a long soak with concentrated Happy Camper will resolve the sensor issues...
    Rich
    2019 T@b 400
    Bellingham WA
    Horigan said:
    . . . I get erroneous full readings.
    The KIB style/brand are well known to provide poor/bad tank levels.  It is a shame nüCamp switched to KIB instead of keeping the SeeLevel System (SeeLevel was not 100% perfect but far better than the KIB style).
    If you want to know more about how the KIB Tank Monitor works, here is a helpful video
    RV Tank Monitor Panel Gives Bad Fill Level Information
