Handle for gray water dump valve on 2020 T@B 320S boondock
riseandshine
Member Posts: 27
Does anyone know the thread specs for the male threaded black plastic handle that screws onto the female threaded pull rod that opens/closes the gray water valve? I tried a range of standard English bolt sizes as well as 10-24 and 10-32 metric and nothing fit, but it seems a little smaller than 10 mm.
2021 T@B 320S, Toyota Tacoma, Olympic Peninsula WA
Have you tried an off-the-shelf RV waste valve handle replacement? 1/4 inch (6.35mm) seems to be the usual standard for these, and they're pretty cheap - anywhere from 5-10 US dollars on Amazon.
Northern VA
2022 T@b 320 S / 2021 Subaru Outback -
I bought a "Camco 39508 RV Waste Valve Replacement Plastic Handle" from Amazon without checking too closely, and it was female, not male, and the thread size looks different anyway.2021 T@B 320S, Toyota Tacoma, Olympic Peninsula WA
FWIW It’s not too difficult to replace the entire valve…
Did this on a 400, $10-15
Valterra T1001VPM Bladex 1-1/2" Waste Valve Body with Metal Handle , Black
https://a.co/d/dPBAnzZ
- 919 Introductions
