Tab 400 2023 - photo of smart solar MPPT 75/15
I just purchased a 2023 TAB 400. I cannot connect via Bluetooth to the solar controller. I look at the 75/15 under the fridge and no light is on and only 2 wires are connected. Can someone share a photo of their set up? Any help would be appreciated. Thanks.
  • RTWCTSRTWCTS Member Posts: 135
    edited June 2023
    deleted post... must have looked at my info wrong...sorry for misinformation.
    2023 TAB 400 Boondock
    2018 T@B 320 Sold
    Racing the Wind and Chasing the Sun
  • pthomas745pthomas745 Moderator Posts: 3,956
    It is hard to tell in your picture and description.  You say "only two wires are connected."  There should be two sets of cables.  One set goes to the "BATT" connection.  The other goes to the "PV" connection.  The "Load" connection is not used in the "normal" setup.
    This thread has some info and pictures on what to look for.  If there are no LED's showing on your controller,  there is obviously a wiring issue. There are also, depending on the battery setup you have in your new 2023, many moving parts. So, tell us what battery setup you have.  Check that fuse in the fuse holder, too.
  • MuttonChopsMuttonChops Member Posts: 1,707
    @JWheel ;  Your Controller Wiring Looks normal/correct to me.
                     See image below.
    {{ as @pthomas745 noted, there should be no connections to the Load Terminals  }}
    Adventures:  54   Nights:  341  Towing Miles 43,780
  • elbolilloelbolillo Member Posts: 381
    Just to confirm, you see no intermittent blue light flashing on the controller? I would check the fuse to see if it has blown.
    Ken / 2023 Tab 400 “La Bolita” (23,000+ miles) / 2024 Toyota Sequoia
    2024 - 3 Trips - 35 nights - 9 National Parks, 3 National Forests
    And while you are in there I would suggest taking a picture of the bottom of the unit so you have the PKU number. This will come in handy if you have any issues in the future with connecting to the unit.
  • MarcelineMarceline Member Posts: 1,599
    edited June 2023
    Maybe it’s just the angle of the photo, but it looks to me like solar panel + line (assuming that’s the green fused line coming off the Wago connector) is connected to the PV - and there’s nothing at all connected to PV +. It almost looks like both the Battery + and - are connected to BAT +.
    At any rate, I would suggest having a good look at the wiring diagram that @MuttonChops posted and make sure that yours matches.
    San Francisco Bay Area
    2013 CS-S us@gi
  • JWheelJWheel Member Posts: 3
    Thanks for your help. I have no light on the controller. I will check the fuse. I’ll let you know.
