Jensen stereo doesn't power on
shliles
Member Posts: 3
Hello all! I'm fairly new to the T@B world and have a 2021 T@B 320S. the Jensen stereo system does not power on. Sounds like a fuse, but any ideas/suggestions?
Welcome to the TaB Family, great travel trailers.
Step 1: Confirm trailer has power.
Do other items, cabin interior lights work?
If not confirm you have shore power or that the Battery Cut-off Switch is On.
Step 2: Radio Unit has two fuses.
One is located on the Power Center VDC Fuse Panel.
There should be a Factory Label indicating fuse circuits.
If only the Radio is on a fused circuit the Power Center 'bad fuse' LED might not
turn-on. Testing the Fuse with a multi-meter is ideal.
Second Fuse is on the backside of the Radio, so the Radio must be pulled out of
the wall to check that fuse. On the plus side the fuse at the radio generally does
not fail.
Good Luck.'18 320 S, pitched axle, 3020HE; PNW based
There is also a large multi pin connector on the back of the radio. Make sure it's pushed in all the way.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York0
