Water Question
Tross2023
Member Posts: 77
2018 TAB 320S. I have the pressure set to 40 or less, otherwise, I get water dripping off the leading edge of the bottom red plastic thingy.
the water is NO dripping from the connections...
TIA
2024 Hyundai Santa Cruz and 2018 T@B 320S
AFAIK that red plastic border edging is completely external. We get water dripping out of the bottom edge when/after it rains0
yea, external, but I see no seepage from the external water connections...odd2024 Hyundai Santa Cruz and 2018 T@B 320S0
@Tross2023, take a look at this..
https://tab-rv.vanillacommunity.com/discussion/comment/113450/#Comment_113450
The city water check valve connection can loosen & leak inside the front compartment behind the toilet. You may be able to reach it & tighten by hand. A leak there will drip through the joint between the floor & front wall. I ended up installing a port hole lower on the bathroom wall for an easier reach to tighten annually..
https://tab-rv.vanillacommunity.com/discussion/comment/129577/#Comment_129577
-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods1 -
I will check for a leak there, I have a camera thingy which I can lower inside and look for loose connections. Great Idea, thanks BrianZ2024 Hyundai Santa Cruz and 2018 T@B 320S0
- 143 Events & News
- 922 Introductions
- 411 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
