Jockey wheel 2010 t@b
Corvairdave
Member Posts: 11
The jockey wheel on my 2010 t@b is failing and I am wondering if there is a direct replacement part? I could modify and install something else, but stock would be easiest. TIA Cheers, Dave
Which running gear do you have? The Alko or the Dexter type?
Towed by 2014 Touareg TDi -
Alko, single wheel
Here are a bunch of threads with suggestions, some quite recent.PS: do you mind if I flip your picture over for you?
Thanks for the reply, and yes, please do!
@Corvairdave, Please describe the nature of the failure and possible picture of it.
@pthomas745, Note - the link did not work for me !Geo & Liz
T@BMahal
'04 #100 -
@geo Try this link from a "Google" search. About the same results. The link above was from a search from the little search window on this page for "alko jockey wheel".
@Corvairdave, I see in the pic that the tire looks flat. The original dolly wheel for DM T@B's is a hard plastic, and that one looks to be an aftermarket pneumatic (air) filled tire. Many DM T@B owners replaced the plastic wheel for either a pneumatic or a solid rubber tire.Geo & Liz
T@BMahal
'04 #100
- 919 Introductions
- 406 Service/Maintenance & Recall Notices
