Thermostat
Estancio
Member Posts: 243
Does anyone have a suggestion for a replacement thermostat in my 2011 T@B? Here's a pic of the old one. Needs to control only the AC/Heat Pump. I no longer have a furnace. Prefer a digital type that does not break the bank.
Stancil Campbell
2011 T@B
Rockingham, NC
2011 T@B
Rockingham, NC
I believe the one below is what newer units have. It works well and is fairly basic. I would double check to make sure you have the right wiring:
Dometic CT Single Zone Wall Thermostat - Programmable AC Control w/Digital Temperature Display- Easy Wall Mount Design for RVs and Trailers https://a.co/d/7ZtyeLk
2021 400 BD
2020 Tacoma TRD Off-Road0 -
FYI, Dometic says the thermostat for my AC is no longer available. While Dometic says I can use their upgraded digital thermostat, it will require a replacement of the control board for the AC unit. It appears to be a complicated process. Though others should be aware!Stancil Campbell
2011 T@B
Rockingham, NC
- 143 Events & News
- 922 Introductions
- 411 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
