Drill through floor in 2023 TAB 400
DaveC
Member Posts: 83
I need to feed two #10 wires from outside the frame into the underbed area of a 2023 Tab 400. I understand the floor is a new composite and don't know how it will cut. Should I use a 1/2 hole saw or regular drill? What is the best way to seal the hole. Thanks.
2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
I would contact tech support at NuCamp to get the best answers to that.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado0 -
Where are you running the wires?DaveC said:I need to feed two #10 wires from outside the frame into the underbed area of a 2023 Tab 400. I understand the floor is a new composite and don't know how it will cut. Should I use a 1/2 hole saw or regular drill? What is the best way to seal the hole. Thanks._____________________________________________________
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia0
