Upgrade to electric brake possible from surge brake on older Dutchman T@B?
marty_m
Member Posts: 9
My TV already has integrated electric brake built in. Has anyone converted surge brake to electric brake on older Dutchman T@B? Any info on how to will be greatly appreciated.
I'd have a trailer shop check it out. I know the Dutchmen use more European axle parts, so it may be more tricky than just bolting on a new electric brake drum and hardware.
I would guess that the entire axle assembly would have to be changed out, IF it would even fit. I use to have an older T@B with surge brakes, I liked them, kind of disappointed when Pleasant Valley switched over to electric brakes.The HobbiT@B, 2015-L, towed by a2014 RAM C/V
Totally different frame from my recollection so would probably take some real jerry-rigging to get the newer axel attached - My guess anyway.
It doesnt sound simple or smooth as I had hoped for. I have been dealing with clunking sound and feel inside my TV from trailer when ever I brake hard. I am pretty certain it's coming from T@B surge brake and was hoping that switching to electric brake will fix this issue.
Have you tried a Quiet Hitch or other hitch tightener? I've found that it makes a world of difference in the clunking noises.Lisa. 2008 T@DA, previously 2012 6x10 SS. Southeastern PA
Yes I use Roadmaster Quite hitch. That was first thing I installed when I heard and felt loud clunk. Made no difference unfortunately.
http://roadmasterinc.com/products/accessories/hitch/quiet.html -
The Roadmaster Quiet Hitch works very well for me, too and is one of my favorite additions.Gil Butler, Folsom, CA, 2015 T@B M@XX CS - White with Yellow tim
- 916 Introductions
- 72 Teardrop Groups & Links
