Aux feed from 7 pin junction box on 400
AndreO
Member Posts: 87
Has anyone fed a primary wire into a 400 from the 7 pin junction box? Looking to add a backup light but Nucamp didn't run a feed wire into the trailer for it. I belive the access into the trailer is above the grey tank making it inaccessible.
AndreO
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
Ontario, Canada
2018 Tab 400
You can take the cover off the bottom and access that inlet. It is not above the gray tank. The underside is in thirds… behind the axle is the fresh water, in front of the axle is the gray water, and in front of that is an empty section where I believe this port is0
