Some time ago, as we were not using the stereo, we got tired of the light from it at night so pulled the fuse. When getting it ready to sell, I reinstalled the fuse and it blew fuse 3 in the panel (lighting, radio, TV) right away. I thought it might have been a weak fuse so replaced the panel fuse and it blew again immediately. I'm guessing I have a short circuit but don't know where to start to troubleshoot it. This is a Jensen AWM965 in a 2014 T@B.
Although there are places for up to 20 wires in the connector on the back of the stereo, only 6 are connected to the trailer. The others are cut off at 6-8 inches mainly for additional speakers according to the wiring chart. This is what is connected:
15 YELLOW MEMORY/BATTERY (+) (this wire is in fact red not yellow)
16 BLACK GROUND
17 VIOLET RIGHT REAR (A) SPEAKER (+)
18 VIOLET/ BLACK RIGHT REAR (A) SPEAKER (-)
19 GREEN/ BLACK LEFT REAR (A) SPEAKER (-)
20 GREEN LEFT REAR (A) SPEAKER (+)
The only odd thing, noted above, is that the wire at 15 is red not yellow.
Additionally, loose in the space behind the stereo are two wires, both with tinned ends. One is red and labelled +12VDC and the other is red and black and labelled GND. I'm sure they weren't touching anything else when I inserted the fuses. I intend to put electrical tape on them unless I find they need to be connected somewhere.
I might also mention that the 12V battery is removed, the trailer is connected to my household 120V with a heavy duty extension cord.
I'm not knowledgeable about electronics so don't know where to start to troubleshoot this so any comments or suggestions would be most welcome.
(the other red wire is probably the #8 and would not be used. But good idea to cap it off. )
Southern Maryland
2023 Ford Maverick XLT
The Finger Lakes of New York
