Victron Smart Shunt IP65
cid69
Member Posts: 27
Getting ready to purchase a Victron Smart Shunt and see there now is an IP65 weather resistant version. I cannot however find any comparisons to the non IP65. Just wondering if there is a "trade off" of some kind to get the IP65. Both are the same price and all things being equal I would choose the IP65.
2017 T@B 320S, 2023 Nissan Frontier, Parker, CO
No trade offs. Performance wise they are the same except for the IP rating. IP stands for "ingress protection". The first digit denotes the degree of protection against solid foreign objects. The second digit is the degree of protection against liquid intrusions.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia1 -
I have the IP65 and there is one tradeoff. If you want to add a temp sensor then you will need to cut and splice one of the wires. You don’t need to do that with the other one.1
Thanks, elbolillo and skibug. IP 65 it will be!2017 T@B 320S, 2023 Nissan Frontier, Parker, CO0
What’s the install on these shunts? Does it replace something else, so wires are all terminated and easy to move over?2026 Haven2023 Tab 400 - sold
2015 Audi Q7 TDI
Northern Ohio0 -
@Robermcm Generally it won't be replacing something else. Most systems don't have this installed as standard (Unless your Tab came with the factory Lithium upgrade install). All loads and chargers get connected to one side of the shunt. The other side is connected to the negative of the battery. If the system doesn't have a shunt installed already, there might be a need for some cutting of wires and connectors being attached. The install is quite easy.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia2 -
https://www.victronenergy.com/upload/documents/Datasheet-SmartShunt-IP65-EN.pdfRobermcm said:What’s the install on these shunts? Does it replace something else, so wires are all terminated and easy to move over?
