Can anyone fill me in on why “overheat blue fail” showed up on the Alde heating system? I have had to deal with “gas failure” a lot, with inconsistent results but this is the first time for the “overheat blue fail”. The heating system seems to be very touchy. Any insights on how to deal with and correct these two messages would be much appreciated.
0 ·
What is "Overheat blue fail"?
This error can occur if the boiler is running at high effect while there are air pockets in the system.
Bleed the system thoroughly, see user´s manual.
Check that the fluid level in the expansion tank is at least 1 cm over the min-line when the fluid is cold.
This can also occur if the circulation pump is broken or disconnected from the boiler.
To reset the error,
The glycol temperature must drop below 41°F (50 °C)
Break and reconnect 12 V to the boiler.
If the error persists, contact Alde Service Partner.
The blue sensor on the boiler body has registered a tempera-
ture in excess of 100ºC, or break/short circuit.
Probable reasons for the fault:
• Air in the heating system.
• Insufficient circulation or pump not working.
• The sensor has been damaged.
• The electronics are not monitoring the temperature.
OHEAT
Caused by:
The red sensor on the boiler body has registered a tempera-
• See OHEAT 1
Caused by:
The heater has attempted to light the boiler repeatedly, without
the electronics receiving the signal from the sensor that moni-
tors the flame.
• No gas supply or insufficient gas supply in the vehicle.
• The electronics do not send a signal to the gas valve.
• The gas valve does not open.
• Impurities in the heater’s gas pipes or nozzle.
• No spark from the electronics.
• The spark electrode has been damaged or is incorrectly
mounted.
• The sensor circuit in the electronics is not working.
• The sensor has been damaged or is incorrectly mounted.
• The exhaust/intake hoses have been damaged or are incor-
rectly mounted.
• Insufficient battery voltage or contact fault in cable.
• Break/short circuit in sensor no. 2 (red cable).
