Anyone towing a Tab 400 with a Nissan Frontier 4x4 crew cab with tow package?
lkc001
Member Posts: 881
I have a Tab 320S now and tows like it's not even back there. Possibly looking at a Tab 400. How does the 400 tow for you? I do not need a sway bar for the Tab 320S never had sway even with big rigs passing or windy conditions.
2018 Tab 400
The 400 tows steady and straight but catches a ton of air. Initially we towed with a VW Touareg, but moved to a Ford F150 PU for more HP, torque, and storage space. Never have needed a sway bar or weight distribution hitch.
I highly recommend the Anderson WDH. I towed our AVIA from Kansas City to Red Lodge, Montana with our '16 Grand Cherokee Ecodiesel. I was really worried about the Grand Cherokee being close to maxed out. It performed fantastic with the Anderson properly dialed in.
If you get one torque those chains so your Frontier has no more than 1" of squat and I think you will find the Frotnier pulls it just fine. The less squat the better the anti sway will work.0 -
Don't have a Frontier but tow our 400 with a Titan and it tows great. No need for WDH at all. The Frontier should have plenty of hp and torque to tow a 400. You'll need to watch your tongue weight and sag. I'm not sure what your max tongue weight is but I'm sure you would be fine. Our 2021 400 has a tongue weight of somewhere from 380-400lbs and a loaded weight, with empty water tanks, of about 3100lbs. I did add some Road Active Suspension (RAS) and sumo springs to our Titan since I have a camper/topper on it that weighs about 400lbs. It does an amazing job with eliminating sag. If you have any sag or want to carry more in the bed I would recommend it. Takes just a few minutes to install and rides great when loaded or unloaded. I'm not a fan of WDH as they can put tremendous strain on the trailer and vehicle frames under certain conditions. Your truck may be fine with some sumo springs and or some RAS.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado2 -
What model Frontier? I had a 2018 Pro4X and the payload was only 880lbs. With a tongue weight of 400lbs and a couple of passengers you aren't left with much leeway.0
bump--anyone else towing with a Nissan Frontier SV 4x4 with tow package?2018 Tab 400
We have to be talking two completely different configurations. Max tow rating on Frontier that I showed above--2016 Frontier SV 4x4 crew cab with tow package with larger tranny cooler is somewhere between 6,300 and 6,500 and payload of 1,500 lbs--information directly from Nissan. I now tow my Tab320S in Colorado mountains a lot, and I do not even know it is back there, and with the overdrive button "Off" it never goes above 3,500 RPM even on steep, long climbs.BrianR said:What model Frontier? I had a 2018 Pro4X and the payload was only 880lbs. With a tongue weight of 400lbs and a couple of passengers you aren't left with much leeway.2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab1 -
Easiest way to confirm your specific trucks payload is to look at the sticker on the drivers door frame. Frontiers can can have a payload anywhere from about 900lbs to about 1400lbs depending on options. I don't think your truck will have any issues with the towing capacity but payload and tongue weight are other things you'll want to consider. I know people tow the 400 with Tacomas and have no complaints.2021 T@b 400 BD "Vixen Gail"
We have sumo springs and use a friction anti-sway bar. The springs work great and eliminate sag. I feel the friction sway anti-sway bar is more of an insurance policy but we have had a couple of instances of sway but I was probably driving too fast. We have a 2020 Tacoma TRD Off Road.2021 400 BD
2020 Tacoma TRD Off-Road0 -
Thanks for the info— if I move up to a Tab 400 will definitely get the Sumo Springs— I really like my truck & how it handles & towsmanyman297 said:We have sumo springs and use a friction anti-sway bar. The springs work great and eliminate sag. I feel the friction sway anti-sway bar is more of an insurance policy but we have had a couple of instances of sway but I was probably driving too fast. We have a 2020 Tacoma TRD Off Road.2018 Tab 400
Like someone else mentioned, Frontiers have a lot of different configurations. I didn't have a trailer when I bought my truck so didn't pay attention to payload capacity. Once we bought the camper I educated myself and I was surprised at the differences. The truck has loads of power and the transmission handles towing without any issues. Mine just had a very low payload(door sticker) and needed/wanted an upgrade.lkc001 said:
We have to be talking two completely different configurations. Max tow rating on Frontier that I showed above--2016 Frontier SV 4x4 crew cab with tow package with larger tranny cooler is somewhere between 6,300 and 6,500 and payload of 1,500 lbs--information directly from Nissan. I now tow my Tab320S in Colorado mountains a lot, and I do not even know it is back there, and with the overdrive button "Off" it never goes above 3,500 RPM even on steep, long climbs.BrianR said:What model Frontier? I had a 2018 Pro4X and the payload was only 880lbs. With a tongue weight of 400lbs and a couple of passengers you aren't left with much leeway.1
