KIB Control Panel Issues
Texodus
Member Posts: 1
The main control panel in my 2021 T@B 320S has the following issues:
I'm guessing since all of the values are wrong it isn't any individual sender but the panel itself. If so, are these panels serviceable? If not, where can I purchase a replacement?
Thank you in advance,
Texodus
- All values are WAY off. That is, battery and tank indicators are grossly wrong. The battery shows low when fully charged and tanks show full when empty.
- When the Pump switch is in the ON position, it also turns on the front porch light at about half brightness. (I guess some sort of grounding issue.)
Texodus
Try using the Forum Search Function; KIB and/or Tank Sensors
To get an overview understanding of the issues/operation of the KIB System, there are several threads.
Attached PDF file has basic KIB Troubleshooting
Be aware KIB System is junk and known to be near useless'18 320 S, pitched axle, 3020HE; PNW based
Adventures: 50 Nights: 415 Towing Miles 50,6501 -
The buttons on my control panel have become erratic and required a lot of jiggling to get a reading. I was able to find a replacement from "PDX RV LLC" in Gladstone, OR. It was with the help of ATC Service in Elkart, Indiana.1
