I have a T@B 400 2018 with the original dual 6V batteries in it. I find that the batteries will only keep the fridge running for about 8 hours before the batteries are too low and the fridge cuts out. I had them tested two days ago and the mechanic said they seemed fine. I cannot think what else it could be other than the batteries are not holding a charge. Any ideas? Also if I replace the batteries what would be a good replacement battery? Thanks
0 ·
https://www.litime.com/collections/12v-batteries/products/litime-12v-200ah-lifepo4-lithium-battery?gad_source=1&gclid=CjwKCAjwlbu2BhA3EiwA3yXyu_S1hTdtust9rka-iaesiTvqgpVKtR-rJvW3mp20aFJmvCkQnESTDhoCCRkQAvD_BwE
My factory install looks like this and the dealer added a solar port on the driver side. I have no inverter but use a Renogy 100W portable panel with a charge controller.
Is this the same location in the 2018?
2019 T@B400 Boondock Lite "Todd"
2020 Tacoma TRD Off-Road
2013 CS-S us@gi
This, plus everything else that people have mentioned about solar and a WFCO upgrade tops it off. It totally converted the boondocking experience.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
