Does anyone have experience with connecting Toyota hybrid. Dealer isn't helpful and I've seen conflicting info on ability to use 7 pin connection on this car. Any experience info would be appreciate.
One option is to forego the 12V+ charging line and just run brake control and ground to the 7 pin, along with the lights of course. That eliminates the need to find a 12V source on the RAV4. I've pulled the fuse for our 12V+ since I don't want to worry about my T@b lithium battery interacting with vehicle charging system. Note I have solar that charges while traveling.
A good RV place may have more knowledge of wiring to Hybrids.
The issue of wiring connection aside, perhaps a more important consideration is the RAV hybrid's towing capacity. A quick online search for RAV4 hybrid towing capacity seems to indicate that the 2nd generation model available since 2019 has a capacity of 1750 lb while the RAV4 Prime ups that to 2500 lb. What's the lightest T@B weigh?
Susan & Bill, Yarmouth, Maine 2024 T@B 400 Boondock Black Canyon 2024 Kia EV9
I have an old TB (2004) rated at 1900 lbs. Not looking to haul large distance or rough terrain, just local jaunts....At one point used a 2012 Forester and it generally worked fine...
2024 Kia EV9
