Towing TAB CS Camper With Bronco Sport
Boatlife
Member Posts: 5
Has anyone towed a TAB CS or similar sized camper with a Ford Bronco Sport? The Bronco Sport Badlands addition is rated for 2200lb towing capacity. The TAB CS is around 1800 lb dry weight, so depending on loading, it will be close to the max rating for the Bronco.
Seems optimistic to me. Don't forget you'll have gear in the trailer and bodies in the Bronco.Boatlife said:Has anyone towed a TAB CS or similar sized camper with a Ford Bronco Sport? The Bronco Sport Badlands addition is rated for 2200lb towing capacity. The TAB CS is around 1800 lb dry weight, so depending on loading, it will be close to the max rating for the Bronco.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
manufacture's marking departments often overstate capabilities - It's best to be under 60% of their stated towing capacity
TV:2019 Nissan Frontier PRO-4X With an Old Man Emu liftTrailer: 2019 T@B 320 Boondock with a Lock&Roll Coupler & Jack-e-upCustom fabricated metal bottom claddingCalifornia, USA0
