How to remove fridge in 2008 Tab
carlwaterer
Member Posts: 1
Have a 2008 Tab. Fridge is a Norcold model 3163 - GH26R , RV fridge. Have an odd smell coming from outside, side vent so wanting to remove fridge and check for repair. Having trouble removing fridge....only comes out an inch or two. Is there something I need to disconnect which is maybe holding it from being removed. Thanks if you know the answer. Carl
I know this is an old thread, and I don't see an answer. So for those who need to know... You have to disconnect the exhaust from the outside vent. The round vent on the outside front. Then you also need to remove the cooktop and disconnect the LP connection and a couple of wire connections 12VDC and 120VAC. Take your time! Before starting be sure the LP is off, and your not connected to shore power.Romana - 2005/6 Thor T@B T16
Port Townsend, WA1 -
Sorry that I missed this back in April. There are a couple of detailed threads that show the items that Romana mentioned. The photos and descriptions from "FuzzyYanni" will help you in the quest to remove the fridge.
Towed by 2014 Touareg TDi0
