Battery Upgrade for the 400
Jax0913
Member Posts: 72
Finally upgraded the original 225ah AGM in our 2018 400! I went with the Li Time 280ah lithium bluetooth battery.
I pulled the false floor and moved the supports so I could move the battery back a bit and open up the front access to the under bed storage a bit more. We have 200watts of solar on the roof and another 100 watt suitcase so going to ride out the factory converter as long as possible. The battery says to disconnect charger when not in use. I have fuses I can pop between my controllers and the battery. Does anyone do this?
2018 T@B 400
2020 Toyota Tacoma Double Cab
3
