360CS Major Component Locations
Hi,
As I contemplate how to add a second battery and possibly an inverter/with transfer switch  like I had in my 320, I want to pass on some photos of my first look of where components are in a 360CS.  I thought others maybe interested.
There is a huge space to the rear of the AC.  I wonder why they did not put the batteries there?  It's flat with plenty of room.  The WFCO is right there.  Maybe an access issue?    I would like to find out from Nucamp why they did not use this location.  Seems ideal for an upgrade.   At first glance, the only challenge is to get the OEM solar wires back there from the front battery compartment.  Since they are only 10 AWG, seems doable, just need to fish them around bathroom and down driver side wall.
From when we first looked at a 360CS at an RV show, they added a slide out for the solar controler, shunt and glasco fuse.  I added our Level mate.  The battery is very secure in the tray.  When I first saw this, I wondered about losing cabinet space.  But there so much cabinet/storage  space in a 360, it's a non issue for us.
The other cabinet is the Alde 3030 area.
2025 360 CS
Southern Maryland
    @Yoshi_TA, Thanks those type of systems pictures are so valuable.
    Just wish the endless Youtube Reviews would include 'systems" information.
    Soapbox:
    Just think of the storage if a Window A/C was used instead of an Air8!  {and don't get me started on the Fridge being too big, Kitchen counter too small, no black tank of the 360S . . .
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 597
    edited June 2025
    Hi,
    For those interested, here is the 360CS (non lithium package) wiring diagram.  I am adding  a larger capacity  battery   (and an eventually an inverter) in the back  where  they place it for the non CS model.  The only challenge is routing a single wire from the OEM solar panel wires which are in the front.  But there is plenty of access via drawers and behind the  toilet to get a wire there.  Everything else is easy access.  Also will add a positive busbar.
    2025 360 CS
    Southern Maryland
