Fuse location on 320S 2021 Boondock?
I believe I had the base model, but online says the fuses are located in the battery tub?  My older model they were under the driver’s side bench.
2021 320S Boondock
2021 Toyota Tacoma
  • SLJ
    SLJ Member Posts: 669
    There should be a fuse on each +line at or near the + terminal on the battery. They are in-line in a rectangle rubber case with a cap. The feed to the converter is 30A if I remember correctly. There is also a row of fuses inside on the front panel of the WFCO converter for the different DC circuits.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
