New solar set up
Mellow_Yellow
Member Posts: 356
Photos of a new solar setup: a 200W Renogy foldable solar blanket with a 30A MPPT controller.
The MPPT controller is not waterproof. So I mounted it to a cutting board with hooks to hang it inside the tub while in use. I will disconnect it and store it in the TV while under tow.
The solar blanket is secured along a line that is tied to each of the push handles and then runs along the curved top of the T@B. It functions like a pulley system to raise/lower the solar panel after it is attached to loops on the line using S hooks. You can see the line if you zoom in.
The driveway test was a success. Field testing is next week! I’m very excited to see how much more efficient this setup will be in off season, off grid conditions. My old setup was a 100W Renogy suitcase solar with an integrated weatherproof controller.
5
How is it doing?2013 MAXX T@B towed by a 2015 Volvo S60 5 CYL AWD Sedan
Seattle, WA -> Palm Springs, CA0 -
Nice! Thinking about doing same thing with my 2 Bluetti 120W folding solar panels. They have grommets on the ends so should be easy but want to use something that won't do anything to the pant when I pull them. How is it working for you so far?
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
"Our favorite trip will always be our next one"0
