on recent Tab 360's is refirgerator compressor area vented to outside?
levbob
Member Posts: 27
Based on postings, new Tab 360s have a fan behind the refrigerator. Is there also a vent to the outside to let the hot air being the fridge egg vented? Does the fans blow out the vent?
Thanks.
Thanks.
It may be that the lack of response to your question is due to relatively few 360 owners on the forum. I have a 400. My experience is that compressor-based rv refrigerators do not vent to the outside. Only the 3-way propane ones do that. Also, most 12 volt, or 120/12 compressor refrigerators do have a fan, positioned near the compressor and coils; especially the latter. This fan may not be visible unless one removes the refrigerator from its enclosure. The fan is either at the top or bottom in the back, depending on design. Isotherms that I have seen place them on top at the rear.0
There is no external exhaust since it does not burn propane. There is no fan other than the built in venting at the top of the front face. The isotherm is pretty quiet and efficient. Is there a problem?0
