Inverter switch 2018 Tab 400
bellimages
Member Posts: 31
It's becoming ever more tricky to get the inverter switch to turn on and turn off. I have to press the button several times. It seems that it helps if I press the button hard.
I assume that it's the switch, and not the inverter. If so, where I can get a new switch?
Please respond directly to my email, since I rarely check the Forum. Thanks!
bellimages@mac.com
bellimages@mac.com
2018 Tab 400
Nissan Frontier PRO-4X (4.6 liter automatic)
Roof mounted solar panels
This appears to be it. If the remote part is failing, you may be able to just remove the panel from the wall and connect the cable already installed.
Towed by 2014 Touareg TDi0
