2018 Tab 320S Lithium Converter Upgrade
KevinH
Member Posts: 1
I wanted to upgrade my converter to be able to handle a new LiTime 12 volt, 100 amp Smart Battery. My solar charger has Lithium as an available option, so I'm good there. My original converter is the WF-8735/8740, but the replacement one from WFCO w/ Auto Detect gets horrible reviews. I've decided to go with the Progressive Dynamics 4000 Series Converter w/Charge Wizard. Can anyone share any experience they have with the install/conversion? Satisfaction, function, functionality. I also purchased the LiTime charger that goes with the battery. Thanks in advance
2021 Honda Pilot
2019 Tab 320S
Kevin Halek/ NJ
2021 Honda Pilot
2019 Tab 320S
Kevin Halek/ NJ
If you have the Litime Charger and connect it to the battery, that can take care of all your shore power charging. There would be no need to deal with WFCO or Progressive.There are only a couple of Progressive installs, and this one is on a 2004?And, some other threads about various WFCO installs.
Towed by 2014 Touareg TDi2
