Alternating current from shore power is not connecting to Alde (Solved)
BillCB
Member Posts: 80
The shore power is connected to T@B 400 and all outlets and the microwave work. But I cannot get it to heat the hot water. The heater works using propane but not electricity. I have checked the tiny fuse on the Alde box and it is fine. I cannot find a circuit breaker. What am I missing, please!
Power Center has an Alde ONLY circuit breaker.
It is also common for the Adle power cord/plug to vibrate out of the 120V Outlet in the Alde compartment.'18 320 S, pitched axle, 3020HE; PNW based
Thanks Mutton Chops! By Power Center I assume you mean the central box with all the circuit breakers and fuses. I'll check it again - and the power cord.0
Thank you again Mutton Chops. The plug was loose in the socket - a small push and all is well.
Bill1
