2020 400 How to Disable (not switch off ) Aims Inverter
kdcampergirl
Member Posts: 36
I had a fault on our inverter and now it refuses to run off either by pressing the remote switch (dinette near door) or by pressing the switch on the unit itself. The fault lights (yellow/red) remain illuminated. Can I just disconnect the terminals from the battery?
That might be the only way. The Manual below has some troubleshooting, but nothing that explains this situation or the combo of lights/
Thanks Paul. I’ve been through the inverter and no luck. This is a flaw, IMO and I’ll probably have nüCamp remove it all together. The inverter is completely hard wired, which makes disabling it or replacing it almost impossible. Thanks again.0
In that manual, I see a "fuse" of some sort on the unit near the power switches/lights are, but I don't know if that has ever been mentioned in the groups before, or if it can be removed easily.
Lol! I took out the fuse, thinking i
might’ve blown it. Fault lights still on!! The gremlin is keeping this thing on 😏0
