LiTime 100ah purchase
Replacing lead acid with lithium. Started to place order and see two alternatives. One basic and one with Bluetooth and two heating modes. Which is preferable?
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,304
    The Bluetooth "apps" are relatively new, and are not a good replacement for the Victron shunt devices, as far as battery monitoring goes.  They have caused a bit of confusion with data from the internal battery "monitor" not matching up at all with the Victron devices.
    All lithium batteries these days have "low temp charging protection.'  It is a sensor inside the battery that senses when the battery internal temperature reaches "freezing".  Not the air temp: the temp inside the battery.  If you attempt to charge a lithium battery when the internal "cells" are 32F or below, the battery will be permanently damaged.  The "low temperature charging protection" will prevent this from happening.  The lithium batteries can still be used for powering devices.
    Unless you plan to do a lot of camping in below freezing temps, battery heaters may not be necessary.
    Not sure what you mean about "two heating modes".
  • Alan57Alan57 Member Posts: 15
    Thanks. Two heating modes was the Amazon description. Read description and it seems like a misnomer. Heater comes on at one temp and shuts off at another.
  • GregChrisGregChris Member Posts: 196
    I have a newish Li-Time group24 100ah with bluetooth and low temp protection. I find the bluetooth very informative, better than the victron app. I couldn't believe the difference from my 75ah flooded cell. Instead of 4 to 6 hours of what ever is on in the 2021 320bd, I get 36 to 48 hours with bad solar. If the sun is good, I almost recover completely from over night use. I don't feel I need shunts, or dc/dc chargers. I know Battle Born is the best, but I could buy 4 Li-Times for cost of 1 BB. The Li-Time app and BMS are telling me everything I need to know.
    I will not be doing a lot of camping in freezing weather, but will be traveling the States and who knows. The battery heater kicks in when the core temp drops below 41 degrees and turns off at 50 degrees.  It does require a lithium battery charger initially to start the battery manage system/bluetooth.  I do not currently have a shunt.  So my choice is the basic battery and a shunt, or the battery with the BMS.  Cost is about the same. I don't want to overcomplicate as I am just learning, l just want to know which is being used commonly used.  I want a lithium battery charger either way and am looking at 20 amp options.  Cannot decide between clamps or Anderson connectors. Thoughts?  Also, just confirming, that I can use the charger and still have the wires from the factory convertor attached?  Input is appreciated as I need to place order soon as delivery is 4 to 6 days out and I want to get going. Thanks!
  • HoriganHorigan Member Posts: 780
    I wouldn't attach the new charger to the battery with clamps for a long term installation.  Clamps are fine for temporary solar panel connections.  I would use ring terminals at the battery or Andersons near the battery. You'll need 12 AWG wire for that amperage.  You can attach multiple chargers to a battery.
    Rich
    2019 T@b 400
    Bellingham WA
