Water staining area around outside wall Nautilus control panel inside access to pump
TimandLaurie
Member Posts: 34
The dampness is below black pipe in picture inside camper below the head of bed.
Water is more than likely leaking in from the Nautilus compartment floor. This happened to me. I had to generously caulk around all the seams of the compartment to stop the leaking. The Nautilus compartment is very poorly designed. It should have been a one-piece seamless pan.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia1 -
Keep an eye out for drips when you use the city water and black water inlets.
Our black tank flush connection got the nautilus tends to loosen over time. Every season I tighten the water connections to the nautilus.2021 400 BD
2020 Tacoma TRD Off-Road0
