Has anyone upgraded their shocks on Tab 400 Boondock?
Question:  has anyone upgraded the shocks on their Tab400 boondock edition?  I ask because in only our second season we suffered a break where the kitchen sink pipe joins the gray tank. I can only surmise this was the result of bumping down the interstate. I thought buying the Boondock edition would protect us from such damage, but since it didn’t, I’m wondering if anyone had purchased more forgiving shocks. Ours is a 2023 Tab 400 Boondock. Thanks
  • Horigan
    Horigan Member Posts: 920
    There are no shocks.  The Boondock just has a higher ride height torsion axle.
    Rich
    2019 T@b 400
    Bellingham WA
    MuttonChops Member Posts: 2,078
    Boondock is just a minor body lift.
    Original TAB models had 'standard pitch' axles while the Boondock uses an ~2inch height increase higher pitch angle axle.
    All axles are the Torsion Rubber 'spring/shock' style.
    No leaf springs, no standard shocks
    No TAB is designed for rough road driving.
    Boondock is the lift and marketing.
  • Prlcarey
    Prlcarey Member Posts: 12
    Is there any way to soften the blows of standard interstate bumps?
  • Binghi
    Binghi Member Posts: 417
    Don’t over inflate your trailer tires. I keep my 400 BD at 50 psi, which seems about right.
  • Tabnero
    Tabnero Member Posts: 251
    you could replace torsion axle with Timbren independent axles
  • TourDeForth
    TourDeForth Member Posts: 133
    Trailer tires have stiffer sidewalls to help carry loads and reduce wobbles. Switching to truck tires that have the ratings to carry your trailer will give a softer ride. If your tire size starts with the letters "ST" you have trailer tires. Truck tire sizes start with "LT." I have LT tires on my trailer it still bounces a bit so this may not cure your issue entirely.
    John, Northern California
  • Maxcamp
    Maxcamp Member Posts: 352
    edited October 2025
    Curious and looked these up. Like the idea on an actual structural steel frame such as my construction trailers.
    Without a cross axle to help stiffen the dismayingly flimsy sheetmetal C section frame on the Tab I'd worry about serious frame distortion.
     Our Tab has exhibited torsion flex and heaved floor and cabinets as it is.
    I've thought about fabricating a full length, structural subframe with rear bike carrier hitch.  For the work involved might as well build out a cargo trailer as camper.
  • Prlcarey
    Thanks for the clarification about the Boondocks edition and also the discussion
