Open or Shut?
When at a campground with hook ups (and hooked up) , what is the 'school of thought' about whether to leave the grey water tank valve open, so that it constantly drains, or closed and drain periodically as it fills up?  Has anyone had issues with 'swamp gas' coming up from the sewer hook up and triggering the propane detector?  Cheers!
Ultimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California
  • TourDeForth
    TourDeForth Member Posts: 133
    You can leave it open but to prevent sewer gas from coming back through your vents you can create a P-trap by bending your drain hose into a U shape to trap water like a P-trap. Personally, I’d rather just keep the valve closed and just remember to drain it every other day.
    John, Northern California
    MuttonChops Member Posts: 2,088
    My vote is SHUT
    I don't even hookup the drain hose until it is time to dump.
    Also consider turning-off the city water source when away from trailer for the day . . . so an unexpected plumbing leak does not flood the trailer.
  • jbajor
    jbajor Member Posts: 233
    Great suggestions!  Thank you!
    Volvo XC-40
  • Mickerly
    Mickerly Member Posts: 518
    I'm with MuttonChops. I don't connect the sewer until I'm ready to dump.Having the hose connected with the valve closed is adding another tripping hazard with no side benefit.
    The two sinks in the trailer have traps. they should stop sewer gasses from entering the trailer. I don't connect to get a better flush from the tank. The more full, the better it drags out anything in the bottom of the tank.
    If you were going to use the shower, you may want to let the gray system drain.
    2018 320CS-S
    "Just Enough"
