Towing with a Durango
klaning
Member Posts: 4
Does anyone have experience or advice on towing a t@b360 with a Dodge Durango?
Hi,
There are a few variables that are important to consider. First the TAB. Is it a '25 or ;26 model year and which model 360 the CS or non CS. As they all have different dry vehicle and tongue weights.
Which Durango and how is it outfitted in regards to engine size, tow capacity. design tongue weight capacity and your vehicles gross vehicle weight rating which is max.weight including cargo , passengers vehicle, etc. You don't want to exceed this.
Suggest you look at all these terms and become familar with them. They will help answer if your vehicle is adequate or how close to the upper limit it may be.
2025 360 CS
Southern Maryland0 -
Absolutely, you can tow any tab, including the 400 with a dodge Durango. They tow just as good as the trucks with a few exceptions when you get into longer rvs.
I tow my tab 400 with a 2018 V6 ridgeline fwd.
You will have zero issues towing since every model is designed to tow within the specs of a tab.2018 Honda Ridgeline FWD
2020 400 solo
Fulltime rving since 2006/ tab since 20210
