2025 400 cable wiring
Okpete
Member Posts: 44
Hello. Cannot get reception with Omni king traveler anntena using cable connection with power booster on under bed. Aux, also no reception. However, when I bypass trailer systems and use Omni king power booster ,I get tv reception. Any suggestions.
My 2025 400 came with a wine guard interior antenna connected to the power boost . It’s located behind the microwave.Try unconnecting the omin and then turn on power-boost . Make sure your tv is set to air and scan for channels
.2025 400 Boondock Black Canyon0 -
Thanks, will check out
When I purchased my 2025 400 late last fall , I was told by many that nucamp does not install tv antennas .
A call to nucamp and they told me a limited number of 400 boon docks had the wineguard interior antenna. My vin number verified this .You can remove the micro wave easily . For screws on the trim and it slides out .2025 400 Boondock Black Canyon0 -
@MOS2 @okpete Another NuCamp surprise! I hate when this happens. If anyone can get any photos of this antenna setup, it will help.A couple of years ago, NuCamp claimed they had installed a "permanent" water pressure regulator on the 2022 models. It managed to make it into a few trailer builds, but....it didn't work, so NuCamp stopped installing it. For a couple of years, owners firmly believed they all had a built in pressure regulator, and owners were learning all about the Famous Yellow Flapper valve as a result.
Hi,
I don't have a picture of the antenna in mine (still looking) but here is a picture of the hidden booster/amplifier (the Winegard small white box..i believe that is it..or maybe it's a splitter, but there is Winegard label on the it ) in a 360. It's also located in a hidden cubby behind the microwave. It is USB powered. Another 360 owner showed me a picture of a flat antenna his came with behind the microwave (second picture) , but mine is not located there. I tried to follow the cables, ran out of arm length and view. I would think there is an antenna somewhere, since this other device is there. I emailed Nucamp, and just like the 400. Nucamp said it was put in some 360 builds, but not all.
2025 360 CS
Southern Maryland1 -
